Lost 1st gear in my 6l80 with p0700
Krash
New member
Sep 5, 2015
123
0
0
37
Dallas texas
Driving to work this morning my mil light came on. I turned around and headed back home and noticed there was no 1st gear. Abs light and trac light on get home and pull the codes
In order
P0700
P0856
U0121
Another u code I forgot what it was though.
Anyone see anything like this ?
I recently did a ls3 TB swap
And fixed a bad wheel speed sensor. We had heavy rain last night when I was driving home.
Monday the truck drove perfectly fine idk if maybe water got into a plug or not. I have checked all connections and came up empty handed.
If the abs lost communication with the abs module ebcm then that's why trac light came on. Ebcm sends a signal an abs module sends one back. It didn't. I can look more into at work
Sent from my SM-G935V using Tapatalk
I'm thinking that would cause the other codes as a fail safe "safe" mode correct?
Yes most are happening does it say what to repair or check? That pretty spot on
Send me an email address. I can try to figure out how I can send it.
Not sure if the pics will work. But I can jus take a photo and send it.
its def a ABS sensor not reporting to the computer.
I know this is a forum and the point is to help, but I can appreciate those replies looking from a third party.
:shake: :clap:
