FS: ART arms for NBS - HI
FTC
Just a dumb welder
Dec 18, 2012
133
0
0
43
Hawaii
Set of ART upper and lower control arms. Lowers were built for shockwave/coilovers but I TIG welded flat plates on them to use regular bellow bags. I am a professional certified welder. All ball joints are fresh, 3 months old. One side of the lowers the bj became loose in the bore so it is tacked in so it won't move. Uppers have studs welded to them so the brake lines can be securely attached. The lowers have shock tabs welded to the front side and an accuair tab on the backside, they have no provision for a sway bar. They are currently painted black, but could probably use a better paint job. $500+shipping which I will have to check on pending location cause they are pretty large.
You need.
GLWS, what are you planning on doing now?
Sent from my b hole
I actually have switched over to mmw arms since raising uppers, I wanted my track width narrowed so I had to switch. These arms rode/functioned great while I was using them tho.
Gotcha. I ordered MMW upper/lowers to narrow mine too. Hopefully they'll be here soon.
Sent from my b hole
