brake question
texascowboy316
New member
Mar 20, 2012
80
0
0
45
i still have brake life left but what can i do about the squiling when coming to a stop. its quite annoying please help
Are you positive the squealing is coming only from the pads? If so, you could bend the little wear indicator tabs on the pads out a little bit so it doesn't rub the rotor
sent from your HTC Rezound
Go to any parts store and get that gel shit they sell that goes on the back side of the pads. Most squeaking from pads is caused by vibration of the pad in the caliper. The gel cuts down on the vibration and will usually stop the squeaking noise you hear.
