04 gmc Sierra front end Denali conversion
foreverslamed
New member
Apr 17, 2013
15
0
0
34
Hey guys I'm trying to see if anyone has or knows of anyone who has done a reg cab short bed Denali? Looking to do it to mine just wanted to get some help on how to do it. I've heard ill have to get the Denali rebar and bumper cover, grille and parking lights. Can anyone tell me if the Denali rebar is needed or does the gmc already have it? And this is for an 04 gmc. Just let me know what you guys think. Thanks.
You will need the Denali bumper bar and bumper cover. And since you have a 04 you will have to cut your frame horns off and weld on some 99-02 frame horns, since that's what the Denali bumper bolts up to. Then you will also need the Denali grill, turn signals, and headlights. (Headlights are optional, your existing headlights will physically fit).
Is this what your talking about? Its a 2005 silverado with a denali conversion.
heres my old truck
and what scott said. mine was a 00 so the frame horns were good.but i had to do the denali bar, denali fogs, bumper cover, grille and parking lights
...but i had to do the denali bar, denali fogs, bumper cover, grille and parking lights
Hey Gr$$n$ you may have seen on the "other" forum I'm doing the Denali conversion on my 2000. I have a couple questions...
Did you need the outer braces and if so will the stock ones work?
Did you use the three fillers between the cover and grill? If not, were you happy with the way it looked or would recommend buying them? Oh and are the small end fillers just black or color keyed?
I have the cover, grill and paint, just waiting on the re-bar, fogs and parking lamps. If there's anything else you'd recommend I'd appreciate it.
Thanks
-RedXray
Going to look good Red! A little bit of color matching was all your truck needed. Decided to go over the top and not just colormatch but completely change it up :crazy:
Thanks
-RedXray
i hate browsing that other forum so i didnt see. lol. but yes i got pretty much everything from gm. i was happy with going with the oem setup. and what do you mean by the small end fillers? the clips that attach the clip to the bar? oh and its gonna look sweet on your truck
Thanks Man!
1. Did you use the fillers # 5 & 9
2. Did you use the outer braces # 7
3. What is # 8 used for and do I need more than one
I have the small fasteners and the fogs figured out. Is there anything in the schematic that you didn't need?
I appreciate your help on this!
-RedXray
Thanks Man!
-RedXray
i at first didnt have 5 and it was wavy. so i got 5 and put it in. 9 i didnt use. 8 is the bolt that bolts thru the bar into those bars from the frame to the bumper. and i dont think i used 12 either
Thanks
-RedXray
http://i212.photobucket.com/albums/cc195/RedXray/IMG_4262.jpg[IMG]
[IMG]http://i212.photobucket.com/albums/cc195/RedXray/IMG_4035.jpg[IMG][/QUOTE]
RAY IS HERE!!!!!!!!
:happeh:
[QUOTE="Ginger, post: 144839"]HOLY FUCK Ray is over here.
ive miss you man, your truck is always so clean. and your garage makes mine look like a dumpster[/QUOTE]
His garage makes everyone's look that way. :rofl:
Thanks Man! :shake:
I found the filler (#5) for $87
One more question and I'll have it clear in my head:
The outer brace # 7 do I need to buy these, or even need them, or will my sierra outer braces work?
I was able to match the 99-02 sierra's outer brace(s) part number to the 2002 Denali... Their the same number. This saves about $55 :cool:
Please keep the chrome,
